Tractor Talk Discussion Forum
O/T: Briggs Stratton OHV valve adjustment
MeAnthony
04-27-2006 07:59:32
16.5 hp OHV Briggs. Struggles to crank past compression stroke. Already tried different battery and starter. Cables/connections clean and tight. Local repair guy said it has a built-in compression release and sounds to him like valves are out of adjustment, not actuating compression release properly. Does anyone have valve adjustment procedure/specs for this engine?
Engine tag info:
Model: 313777
Type : 0112-E1
Code : 0002242E
She bought it new in '92, I believe.
Thanks for your time and suggestions.
Anthony
Ichabod
04-28-2006 06:55:11
 Re: O/T: Briggs Stratton OHV valve adjustment in reply to MeAnthony, 04-27-2006 07:59:32
See if your engine is listed below.
Glen in TX
04-27-2006 17:05:21
The decompression is a pin type spring loaded mechanism made on the camshaft. Could be broke or wore out so setting valves may or may not help.
ezyed
04-27-2006 08:35:49
Have same problem with mine. I believe the adjustment is .04. tiney allen screw in middle of big nut.If I remember right
TomTX
04-28-2006 05:51:00
 Re: O/T: Briggs Stratton OHV valve adjustment in reply to ezyed, 04-27-2006 08:35:49
You wrote .04 which would be 40 thousandths, sounds like a lot. Do you mean 0.004 ?
Tom
