Tractor Talk Discussion Forum
Spark plug thead size
jd jim a
04-27-2006 22:17:39
Am I correct in thinking that spark plugs most commonly come in two thread sizes, 14mm and 18mm? What would the thread pitch be, and what tap would I need to run through the threads of a head that uses a 14mm plug?
Jim Bruce
04-28-2006 16:57:25
 Re: Spark plug thead size in reply to jd jim a, 04-27-2006 22:17:39
In a pinch, knock the center electrode out of a old plug and use a hacksaw to cut two slots in threads forming an x to make a thread chaser.
Jim in Mo.
04-28-2006 16:01:53
In a pinch, knock the center electrod out of an old plug and using a hacksaw make two cuts thru the threads at right angles to make a thread chaser.
Glen in TX
04-28-2006 12:41:40
Yep those are the most common but there were also smaller 10mm and 12mm also. Old 46 Cheverolets and some old Cadillacs used the 10mm plugs.
Mike M
04-28-2006 08:43:38
What are you working on ? Some of this old iron takes 7/8-18 and 1/2" pipe threads
KEB
04-28-2006 07:54:27
Use a thread chaser, not a tap. Taps are designed to cut threads, thread chasers are designed to re-form them. If the threads are bad enough you have to use a tap, you"d probably be better off boring it out & putting in a helicoil.
Keith
Joe (Wa)
04-27-2006 23:29:17
These threadchasers work ok if the existing threads are not too far gone. Take it slow, work it back & fore.
Joe
Bob
04-27-2006 22:32:29
14 MM X 1.25 pitch
18 MM X 1.5 pitch
