Tractor Talk Discussion Forum
JD 4030 hydraulic question
Willy P
04-29-2006 06:36:24
On my JD 4030 it keeps blowing the o ring in the pressure control valve. What could be causing this? Would the valve be sticking or maybe needs some more shims under the spring? Also the transmission light will come on and go off when idled down. Thanks
HTR
04-29-2006 17:57:04
 Re: JD 4030 hydraulic question in reply to Willy P, 04-29-2006 06:36:24
I don't think changing shims, or a stuck valve, will have any thing to do with the Oring blowing. The fitting, that the Oring is on, is going to see the pressure, that the pump is set at all the time. I guess you have the new style fitting, with the swivel?
How much vibration does the pressure line have in it, and are all the clamps, inside the frame rail, and the junction block bolted tight? A slow high pressure internal leak can cause the line to vibrate, and hammer on the pressure control valve. Also, an improperly set crankcase outlet valve, in the main pump, will cause the pump to hammer.
I think about the only thing to cause the oil light to come on, related to the pressure control valve, would be the inner Oring, on the sleeve, that the valve is in, is blown causing an internal high pressure leak.
Bad news is, most all the time the leak is caused by a hair line crack in the housing, from the threads out. If that is the problem, good luck finding one.
Anon
04-29-2006 09:55:19
Is your transmission filter plugged?
Tx Jim
04-29-2006 09:31:33
Willy,the hyd. pressure on a JD 4030 is controlled by stroke control valve in main hyd pump. The stroke control valve doen't have shims to my knowledge. Is this where o-ring is blowing? I am unaware that a JD 4030 had a tranns.light from the factory but if yours does it would probably indicate low tranns. pressure. Tx Jim
