Tractor Talk Discussion Forum
Hooking disc mower to MF1105
KYfarm
04-29-2006 14:15:12
third party image
Anybody with any good thought on how to hook the chains from a NH disc mower to the top line on my MF1105. My past tractors had a removeable top pin to hook the third link to and the chains.
This 1105 has a much heavier set-up but no easy method for attaching the disc mower, any suggestions?
barnrat
04-29-2006 17:26:12
 Re: Hooking disc mower to MF1105 in reply to KYfarm, 04-29-2006 14:15:12
The vertical pin should come right out with a couple of good hammer raps, it looks to be rusted in place(replace with longer pin if needed). Only thing thats different on the 1000 series masseys is that the pin is vertical instead of horizontal like most 3 point top links. You may have to use a clevis when hooking up your chain, that is what I had to do when I barrowed my neighbors Vicon disc mower. What will really make you scratch your head is try to hook up a post hole digger. One Last thing, dont mess with the horizontal pin that is bolted to the tractor.
KYfarm
04-29-2006 18:27:35
 Re: Hooking disc mower to MF1105 in reply to barnrat, 04-29-2006 17:26:12
Thanks for the help, I see, one chain on top and the other on bottom instead of either side.
Thanks alot!
edchainsaw
04-29-2006 18:26:37
you can mess with that horizontal pin.. it is part of the draft control setup that plate is a big spring..
and I have a vicon disc mower and have no chains what so ever so I have no clue why you would need to :)
Roy in UK
04-30-2006 02:55:19
 Re: Hooking disc mower to MF1105 in reply to edchainsaw, 04-29-2006 18:26:37
I am a bit baffled too, what is the chain for? is it a fully mounted mower or trailed mower with an "A" frame that fits the linkage. I have had a Vicon 8 foot mounted disc mower too. The MF 1100 we had would have been a bit like over -kill on that one.
barnrat
04-29-2006 18:37:17
I"ve been around 1000 series Massys all my life. I know all about the draft spring on the top link, but it was better left alone for this discussion.
