Tractor Talk Discussion Forum
OT best Paint remover?
I Bleed Green
04-30-2006 13:10:07
Im going to be restoring a baby bed. I want to take the paint off down to the wood. What is a good paint remover??
msb
04-30-2006 19:43:51
 Re: OT best Paint remover? in reply to I Bleed Green, 04-30-2006 13:10:07
Do you have a place that dips furniture? That is the easiest way of getting it done.Check your local yellow pages.
seventy2ten
04-30-2006 16:56:03
while your at it get the white paint off your tires.
I Bleed Green
04-30-2006 17:11:18
 Re: OT best Paint remover? in reply to seventy2ten, 04-30-2006 16:56:03
What does my post have to do with tires?? Does your mommy and daddy know your posting here?
Leland
04-30-2006 16:47:17
Zip strip if you can find it
Mike in Ohio
04-30-2006 14:07:01
The last time I did any of this Ifound a citrus based remover that worked well and wasn't troxic. I don't remember the brand, I will check if I still have some left in the basement and get back later. Mike
doogdoog
04-30-2006 13:46:03
Aloha, Don't know what's the best but be sure to neutralize the remover so it won't bleed thru and harm the baby and also, use a safe paint.
Mahalo,
doogdoog
I Bleed Green
04-30-2006 15:12:50
 Re: OT best Paint remover? in reply to doogdoog, 04-30-2006 13:46:03
Im going to take all of the old paint off because im sure it has lead in it. You can be sure i will do whatever it takes so its safe for the baby.
Paul in On
04-30-2006 15:41:43
 Re: OT best Paint remover? in reply to I Bleed Green, 04-30-2006 15:12:50
If I recalled, I started to strip a chair of some sort and since it was lead base the fumes were terrible. I don't know if a respirator does the trick or what but it never got finished.
J.C.H.
04-30-2006 15:33:10
What ever you use be sure to give it a very good bath in TSP and Water Clean up.I would recommend a Citrus Base product for a baby bed. Stripeze is to severe and Toxic if a Child may chew on any part of the bed.Ask your supplier.
