Tractor Talk Discussion Forum
1010 w/out live power
cagacose
04-30-2006 19:09:12
Anybody do much mowing/bushogging with a tractor without live PTO power? Moving to a bigger tractor and it does not have live power. Can it be converted? Can P/S be added?
Also, the tractor is an RUS 1010 "Special" What does the special mean? The guy I bought it from is a large collector and he indicated that some of the 1010's were problem machines. He wasn't too worried about this one though. Any thoughts?
JDknut
05-01-2006 09:12:17
 Re: 1010 w/out live power in reply to cagacose, 04-30-2006 19:09:12
The 1010 is basically a two-cylinder generation 420/430-chassised Deere with a four cylinder sleeve-and-deck engine. When Deere developed the NewGen, they lavished their engineering attention on the bigger tractors (3010/4010 series), and the smaller tractors slurped hind mammary, so to speak. Deere didn't get around to revising the 1010/1020 until 1965. That said, the 1010 isn't a bad little tractor especially in the gas mode. The Diesels were prone to sleeve leakage (seal failure under the increased vibration and stresses of Diesel operation) and thus a shorter service life, but the gassers were better in that regard. If you don't have live power, put an over-running clutch on the PTO so the brushog doesn't try to propel the tractor when you push in the clutch. Over-running clutches are easy to find at a tractor supply shop or any dealer worth their salt. just my $0.02. wish you luck.
lloyd in sc
04-30-2006 20:52:48
When I stopped climing that tree in my 1010 (bushogging) I got an override clutch & installed it on the PTO shaft. Now when I put in the clutch the dang thing STOPS. It does make life less intresting.
Bob
04-30-2006 20:02:56
Third Party Image
This 1010 Special is on the Deere lot at Devils Lake, North Dakota. It's pretty rare to see one up here on the prairie!
cagacose
05-01-2006 03:56:48
 Re: 1010 w/out live power in reply to Bob, 04-30-2006 20:02:56
What is that dealers name Bob?
Bob
05-01-2006 07:19:02
 Re: 1010 w/out live power in reply to cagacose, 05-01-2006 03:56:48
Devils Lake Equipment (701)662-4948.
(No, I don't have a connection to them, just thought it was a cute little tractor.)
Ray
04-30-2006 19:41:47
A 1010 special is a stripped down version of a
1010 to make it cheaper to purchase.It didn't have PS or live pto,some had a pan seat like an 8n ford.
