Tractor Talk Discussion Forum
Gooseneck Hitch Question
MH
05-01-2006 09:54:19
I've got a 89 F350 with a dump bed. I want to attach a gooseneck hitch to the frame. Are there any guidelines on where I should position the ball in relation to the rear wheels?
Also, what is the best way to determine what the axles on my trailer are rated for? No weight listed on the trailers tag, & haven't found any other tags yet.
T_Bone
05-01-2006 16:55:15
 Re: Gooseneck Hitch Question in reply to MH, 05-01-2006 09:54:19
Hi MH,
From reading alot of install instructions from several mfg's, there's less that 1% weight difference 4" behind the axle to 4" in front of the axle.
Me, I installed mine dead center and it pulls great. The only other thing you need to watch for on like a 5th wheel install is cab clearance in a jack knife turn.
T_Bone
Mike M
05-01-2006 11:24:58
We just hooked the one on our 1981 F350 right to the bottom in the dump bed. Has worked fine for years.
MH
05-01-2006 10:42:59
So it sounds slightly infront of the rear axle. That is what I was thinking, but did not know how far. Thanks for the input.
MH
JD4840
05-01-2006 10:30:43
The ones I have had installed were placed 3 inches in front of the center of the rear axle.
nballen
05-01-2006 10:17:32
The shop that installed a couple hitches for my folks always said to place the center of the hitch ~1/2" to ~1" in front of the center of the axle. It"s been 15 years, so I don"t remember exactly.
Where ever you place the hitch, make sure it is NOT behind the axle - as that would tend to lift the front of your tow vehicle and reduce ability to steer.
Nathaniel
