Tractor Talk Discussion Forum
super M Farmall--what to look for when buying
bj/8n/mt
05-03-2006 06:35:47
I posted this on the IH board but thought posting it here too couldn't hurt. There is a Super M Farmall at an auction near me this Saturday. I have been getting it done with an 8n Ford but wouldn't mind some more horsepower.
I know of John Smith's site on buying n series and wonder if there is something similar on red iron. If not anything to look for or avoid?
Any help appreciated
Don L C
05-03-2006 18:22:58
 Re: super M Farmall--what to look for when buying in reply to bj/8n/mt, 05-03-2006 06:35:47
Make sure it is a Super M....there are a lot of plane old M's out there with Super m decals on them.....
dhermesc
05-03-2006 08:12:16
One of the main items to look for you won't find without operating the tractor. Popping out if gear is one of the more diffcult issues to fix, even that isn't so common. After that the M and H are pretty much indestructable. The basics are oil and coolant leaks, cracked castings, brake and clutch peddle tension and smoke at start up. There is no common "weak point" in these tractors, IH got it right and didn't screw it up until the early 560s came out. Most Ms and Hs "die" from being parked without a rain cap on the exhaust and that freezes up the engine. Even then they are coaxed back to life sometimes.
Brokenwrench
05-03-2006 07:12:02
I always heard they had a problem with cracking heads. I`d pull the oil dipstick and make sure it aint milky. Other than that, just the basic stuff you check when looking at any 50 yr old tractor. Good Luck Brokenwrench
old
05-03-2006 07:06:15
Well if you know what to look for on a Ford then you pretty much know what to look for on any of them. Most tractors are very close to each other on where problems will be, like leaks, tires, sheet metal etc.
