Tractor Talk Discussion Forum
3 point hitch
slat
05-03-2006 07:31:52
Is it better to have a tractor with a positive down force on the 3 point or a floating 3 point?
slat
05-03-2006 11:57:53
 Re: 3 point hitch in reply to slat, 05-03-2006 07:31:52
I was asking cause I'm looking at two tractors, one is a IH 300 utility with a two point hitch and the other is a Massey Ferguson 65. Just wondering if there was a preference or advantage of one type or the other.
Thanks
Steve
Catskill Pete
05-03-2006 12:57:50
 Re: 3 point hitch in reply to slat, 05-03-2006 11:57:53
The down force feature on the IH fasthitch can be a very useful feature, posthole diggers, back blades etc. They all had a pin in the hitch that when removed allowed them to float like a conventional 3pt, although somewhat limited travel. The down side to them is finding 2pt fasthitch equipment is becoming very difficult.
slat
05-03-2006 20:10:32
 Re: 3 point hitch in reply to Catskill Pete, 05-03-2006 12:57:50
Where is this pin located?
RayP(MI)
05-03-2006 15:51:52
Other alternative is to convert 2pt to 3pt hitch. Have that on my Farmall 200, works pretty well, although there are limitations. Use downpressure to drive steel fence posts. Most other uses are best on float.
RayP(MI)
05-03-2006 15:51:40
Coloken
05-03-2006 10:28:22
I would point out that the Case 400 (not 400B) had a position on the control lever for down pressure. Very nice when diging post holes.
Nebraska Cowman
05-03-2006 10:14:57
very few tractors have down force on the lift arms. Some of the IH 2 points were the only ones I know of. And I never thought is was any advantage. Any time you start transfering weight to the implement you take weight off the tractor and loose traction.
third party image
Even bad boys are just as good as they can be
Wild Bill
05-03-2006 11:58:10
 Re: 3 point hitch in reply to Nebraska Cowman, 05-03-2006 10:14:57
Down pressure hydraulics are a wonderful thing. There must be hundreds of thousands of IH tractors out there with the factory designed and sold "christmas tree" set up. They are wildly popular and very hard to find, they go for crazy ammounts on ebay. They are popular for a reason.
Steve from Mo - dangit!
05-03-2006 08:09:23
 Huh? in reply to slat, 05-03-2006 07:31:52
Those features are not mutually exclusive - you should not have to choose. It's usually a matter of setting a valve on the tractor. If you are building or buying one, it's a matter of choosing the right valve.
