Tractor Talk Discussion Forum
New bearings on Ford 601 Workmaster
springman55
05-03-2006 20:33:21
I recently replaced all the bearings on the steering assembly of my Ford 601. The replacement bearings are made of delrin(teflon). The larger bearings in the steering housings went in fine....the smaller bearing on the steering shaft which replaces a bearing cup assembly was so tight my steering wheel will not turn. Has anyone had this same problem and if so what did you do to allow that shaft to turn freely? Someone at our local Ford dealer suggested using emery cloth to work the shaft smooth and also work the inside diameter of that bearing. Any help you can give is welcomed!
springman55
RAB
05-03-2006 23:17:54
 Re: New bearings on Ford 601 Workmaster in reply to springman55, 05-03-2006 20:33:21
Did bearing fit on shaft before you installed it?
RAB
