Tractor Talk Discussion Forum
Any carb experts out there??
old
05-04-2006 14:45:59
I rebuilt a carb today on a MH 30 MS carb. The tractor will wil just fine, if you remove the main jet, but if you even put your finger over the hole where to main jet goes in the engine will die. So what/where I'm I missing as far as cleaning it?? This is the first carb I have ever had do this to me and I have rebuilt a good number of them. Help please!
Thanks
Greg_Ky
05-04-2006 14:58:04
 Re: Any carb experts out there?? in reply to old, 05-04-2006 14:45:59
Old,
Is that the one the venturi fell out of? If so did you get it installed tight. Just my $.02
kingmondo
05-04-2006 15:03:43
 Re: Any carb experts out there?? in reply to Greg_Ky, 05-04-2006 14:58:04
Is your manifold gasket leaking?
old
05-04-2006 15:02:42
It fit in a little on the loose side but not all that loose. So your saying I might need to try a differant one then
Greg_Ky
05-04-2006 15:12:28
 Re: Any carb experts out there?? in reply to old, 05-04-2006 15:02:42
When a venturi would come loose on the race car it made a huge difference. Can you peen the edges to tighten it up any?
old
05-04-2006 15:18:38
 Re: Any carb experts out there?? in reply to Greg_Ky, 05-04-2006 15:12:28
Don't know if I could or not. But I do have other carbs I might be able to try one from one of the other carbs
Greg_Ky
05-04-2006 15:21:01
 Re: Any carb experts out there?? in reply to old, 05-04-2006 15:18:38
Probably the one that you sent to Dawn to practice on is the one you need. LOL
old
05-04-2006 16:24:26
 Re: Any carb experts out there?? in reply to Greg_Ky, 05-04-2006 15:21:01
Well I tried another one and it didn't help. But I think I may have found the problem. On this tractor the intake manifold has been welded right at the carb mount. I started it with the main jet in and sprayed carb cleaner in that area and as long as I sprayed it ran but if I stopped it would die in a short time. Guess my next try will be 2 gaskets and a little bit of silicone sealer and see what happens. At this point I don't think I have any thing to loose. LOL
