Tractor Talk Discussion Forum
headlight bulbs for farmall h
RIVER BOTTOM FA
05-04-2006 19:43:54
Can I buy 12volt bulbs that will fit the original 6 volt light housing and does anyone know a napa part number if they are available....thanks guys rbf
mlm
05-06-2006 15:32:21
 Re: headlight bulbs for farmall h in reply to RIVER BOTTOM FARMER, 05-04-2006 19:43:54
the bulbs that the cheap fog lights use work good. they are 50watts. don't have the number.
RustyFarmall
05-05-2006 04:47:40
Yes, 12 volt headlight bulbs will fit in the same socket as the 6 volt. Your local Case-IH dealer should have them. If not, try a N.A.P.A. auto parts store. I have also found them at O'Reillys. An 1156 will fit, but that bulb is a tail light bulb. It is much smaller and has far less candle-power. Be sure you specifically ask for head light bulbs.
MSM
05-04-2006 20:21:02
An 1156 should work
