Tractor Talk Discussion Forum
tractor will not start
John Rob
05-05-2006 15:15:43
49 8n ran fine over weekend, parked it on saturday tried to start it tuesday it would not start. Engine turns over fine fire is to the distributor but can not get fire out of plug wires
Dave Sherburne NY
05-06-2006 14:39:43
 Re: tractor will not start in reply to John Rob, 05-05-2006 15:15:43
Used to have this problem with ours in the 50s
Ours was a side dist. Can you get the cap off and
open and close the points to see if there is a spark/juice at the points?
led
05-05-2006 20:40:09
If you have recent rain that is probably a primary contributory cause.
Led
mjbrown
05-05-2006 15:43:54
check to make sure you are getting juice to the coil when the switch is on. Then check to see if juice is going from the coil to the distributor. Then it's ignition parts and plug and coil wires. I'm guessing a cruddy switch or wire connector feeding battery power to the coil.
John Rob
05-05-2006 16:36:17
 Re: tractor will not start in reply to mjbrown, 05-05-2006 15:43:54
new points, new coil, removed switch, straight wired, the coil is hot, points are set at .015, still no fire to plug wires, distributor cap has continuity(sp), 10.13 volts to coil,
old
05-05-2006 19:02:17
 Re: tractor will not start in reply to John Rob, 05-05-2006 16:36:17
Condenser maybe bad and or when you put the points in you got something shorted out in the distibutor, common problem when putting in new points.
old
05-05-2006 15:40:05
When you say fire to the distubutor are you saying you have power to the coil, since that should be a front mount type?? Well if yes, has it rained in the last couple days and is it parked out side?/ If yes then check for woter in the distubutor, slipped points or maybe even a bad coil. You didn't by chance leave the key turned on did you, if so you fried the coil and maybe the points. Just a few things that could be wrong
mjbrown
05-05-2006 15:47:52
 Re: tractor will not start in reply to old, 05-05-2006 15:40:05
Ah yes, I overlooked the year. The front mounted distributors are sensitive to moisture. I had a 9N and hated the distributor. It still works on the same principle though.
old
05-05-2006 15:54:51
 Re: tractor will not start in reply to mjbrown, 05-05-2006 15:47:52
Thats another one of the problems with the front mounts its hard to make sure your getting spark from the coil since it doesn't have a coil wire like the later model 8Ns had. My self I love to hate front mount distributors
