Tractor Talk Discussion Forum
At wits end trying to start 8n
monomechanical
05-06-2006 20:42:47
All: Forgive a long post.
I've got two advanced degrees in difficult subjects and I'm not half as smart as many of you folks. I'm at my wits end--quickly reached regarding mechanical matters--and need help. My 8n--6volt, front distributor--was running last week. It absolutely quit and will not start. It comes close to starting, but will not get going. Occasionally, back fires.
I find that I seem to get such high compression--that's not the right word, I know--that gas vapor will blow out the air intake where it attaches to the carb, when I'm trying to start the engine. (I haven't a clue how to describe/identify why it is that gas vapor should blow out the air/intake and carb gaskets (pre-re-tightened) when I try to start the engine. Seemed at one point to come out around the governor housing, too.)
Some more facts, narrated out of order. 1. I get good spark to cylinders 1 and 2. Weaker spark to 3 and 4. I'll replace two wires on Monday, though it seems improbable that two wires in a new set would be bad. (I put in a new distributor/coil/wires/spark plugs last season: gapped spark plugs and have verified accuracy of setting. (Spark plugs do get very black quickly: too rich a mixture?) 2. The carb floods very quickly. 3. When the engine was running last week, the air intake would "make a gulping sound." Now I seem to get very poor air draw. I took off the oil bath: got slightly better draw, but still not what it was nor is it satisfactory. 4. I cleaned EVERY filter in the fuel line, including the wire mesh at the fuel line elbow (into the carb.). Put in clean fuel. 5. Again, when trying to start tractor, I get TOO MUCH FUEL as it runs out the needle and air intake connection (pre-re-tightened). Have tried to start tractor on dry carb, gradually allowing fuel to spill into carb, to find some happy moment between starving/drowning. Cannot find that point. 6. Have taken off the distributor and coil, to let them air dry: no discernible condensation. The rotor will only fit on the shaft in one way, so I think timing is not an issue. (Dumb inference?) 7.1. Took the entire carb off, blew it out, hoping that since I do not have a tune-up kit--not one available nearby--running air through the thing would take out that single piece of dirt/gunk which keeps motor from starting. Replaced carb, no difference at all: not even with two Hail Mary's and three Our Father's. Also, crossed self: no effect. 7.2. Seems that the float in the carb. is solid, and does not, in fact, fill up with gas: also, is one-quarter inch from surface, all the way to the hinge. (I was thinking the float allows too much gas into the carb. That hunch may still be right?) 8. Came into house to find revolver for tractor, but have cooled off.
So: engine is very, very close to turning over. I get the occasional backfire. But the engine will NOT turn over. Carb floods, and I pull the choke wide open. Still, just lots of whirring and near starting. Perhaps the problem is electrical after all? Ideas???? jim.
Jerry Cent. Mi.
05-07-2006 15:35:02
 Re: At wits end trying to start 8n in reply to monomechanical, 05-06-2006 20:42:47
Have you wiped out your dist. cap? We farmed with one of them when I was young and if I remember right the Dist. runs off the front end of the cam and when the bearing wears it allows crankcase vapors into the Dist. and it coats the inside of the cap. The vapor draws moisture and shorts out the spark. Try a new cap or wipe it out with laquer thiner. Their is a resister under the hood behind the panel that holds the gauges that go's bad quite often. Short accross it and see if it helps. I was always able to do it with a screw drive. Good luck. Jerry
monomechanical
05-07-2006 16:10:19
 Complete Humiliation. in reply to Jerry Cent. Mi., 05-07-2006 15:35:02
Put in all new spark plugs. 8N started within 20 seconds. But it's slightly more complicated.
I would be completly humiliated were it not the case that I suspect the Mrs. switched the wires coming out of the distributor. She switched the three and four wires, I just know it. I swear I checked the wires 30 times.
(Please do not tell anyone about this.)
Thanks to all for the advice.
jim
buickanddeere
05-07-2006 20:53:47
 Re: Complete Humiliation. in reply to monomechanical, 05-07-2006 16:10:19
Use solid core wires or she will begin missing then eventually not starting again.
Richard Scott
05-07-2006 15:09:41
All that fuel running out, etc. you mention sure sounds like carb problems. Many of the ignition related suggestions, although they might cause your trouble, probably don't apply in your case since you are pretty well describing a carb problem.
Here's a simple test if you can shut off fuel flow to the carb: Make sure it is not still flooded. Crank with throttle & choke wide open & no fuel flow to clear the flooded carb. Then spray WD-40 into the carb while someone cranks it. If ignition is good, it should fire (WD-40 is a good substitute for starter fluid). If it fires, it ain't electrical. And if it fires, it will probably run for a couple seconds, further confirmation it isn't an electrical problem.
However, note that if it does not fire, that does NOT necessarily mean that it IS an ignition problem. Could be valves, compression, etc.
No one has addressed your "gulping sound", but that does not sound like an ignition problem either. Considering the poor air draw & this gulping sound, if the WD-40 doesn't make it fire, I would do a compression check for step 2.
What has changed since last week when it last ran? Has it been left out in the rain? If so, maybe it is ignition after all--check distributor cap for any hard to see lines like little, tiny hard to see cracks or tracks indicating cross firing. If the cap is damp on the inside, the current will follow the path of least resistance and a plug in a cylinder under compression has more resistance than one which is not. This would explain your backfiring, but it doesn't explain the flooding.
Good luck & keep us posted. I spent 2 days out in the field last week trying to bleed my Yanmar's non-standard fuel system so I understand your frustration.
Dell (WA)
05-07-2006 13:48:33
..... ....you write..... .."I get good spark to cylinders 1 and 2. Weaker spark to 3 and 4. I'll replace two wires on Monday, though it seems improbable that two wires in a new set would be bad"..... ...make certain yer firing order is correct. 1,2,4,3 CCW. Very eazy to miss-wire sparkies 4 & 3. While good N-Engines will actually run on just 2-cylinders, tired engines need at least 3 and preferably 4-sparkies working. Otherwize you will NOT START yer engine and it will behave as you have described.
You write..... .."2. The carb floods very quickly. "..... ..while flooding carb is most likely caused by yer heavy-handed choking technique, or could be caused by sticking float valve, but it is a very likely candidate for NON-floating float. The float occasionally developes pin-hole leaks in solder seam. SINK yer float in GLASS JAR of HOT WATER and watch for tiny stream of bubbles being forced out.
You write..... .."3. When the engine was running last week, the air intake would "make a gulping sound." Now I seem to get very poor air draw"..... .almost sounds like you have a "stuck" intake valve. When an intake valve sticks open, you ain't gonnna gitt much "suck". Suck (vacuum) is needed to gitt the fuel/air mixture into the engine. Iff'n engine don't gitt fuel/air, it ain't gonnna run even iff'n carb is flooding. Does that surprize you?..... ....respectfully, Dell
Ross Pugh(NC)f
05-07-2006 13:43:39
If you have had spark plug wires off at the distributor cap and put them back on even though they are firing in the right order your timing may be off by 180 degrees. That happened to me and mine was doing the same thing ( backfiring and spitting gas out at choke. Then sometimes gas would pour out at choke valve like yours). A friend of mine got my #1 cyl. on compression stroke, ran the plug wire to the next terminal on distributor that rotor button would hit and rewired it from there, put the cap back on and told me to give it some gas, choke it and start it up; I did and it did, problem solved, wires were in right order just 180 degrees off on firing timing.
Bob
05-07-2006 14:56:47
 Re: At wits end trying to start 8n in reply to Ross Pugh(NC)f, 05-07-2006 13:43:39
The front-mount 8N distributor only goes in one way. It's impossible to get the timing off 180 degree, if the wires are installed as shown in the diagram previously posted.
monomechanical
05-07-2006 09:44:43
 Many thanks for every suggestion. in reply to monomechanical, 05-06-2006 20:42:47
Thanks to everyone for the excellent suggestions. I'll try them tomorrow and get back with a report. Meanwhile, consider further advice on how to catapult 8n into Lake Erie.
Jim.
mjbrown
05-07-2006 13:09:54
 Re: Many thanks for every suggestion. in reply to monomechanical, 05-07-2006 09:44:43
Build a trebuchet.
Bob
05-07-2006 13:19:56
 Re: Many thanks for every suggestion. in reply to mjbrown, 05-07-2006 13:09:54
Like this?
Bob - MI
05-07-2006 09:14:17
My 2n does the same thing when it decides to become hard starting. My guess is that you should start with new plugs. If you post on the 8N board Dell will tell you that unleaded gas fouls pulgs and you can"t see it. Autolite AL437 is the suggested route. If you are getting too much gas on startup you may want to try shutting off the petcock when you start seeing it drain out. This will keep it from flooding real badly and if it starts you can open it back up.
This really all sounds like a number of issues but it can be tied to a tired engine that is low on compression. Try jumping it with 12 volts directly to the starter and see if it will fire off. Don"t jump to the battery! Make sure you have it in nuetral.
My engine is low on compression and can be a real trick to start sometimes and mimicks the symptoms that you are describing. I use a combination of low throttle settings and choking which I think increases the velocity of the air passing through the carb and better atomizes the fuel.
frankiee
05-07-2006 09:01:00
The first thing I would do is check the push rods and do a lash adjustment while there.
Couple years ago the "Farmall H" was acting up and I was worried the engine was shot.
I decided a lash adjustment could not hurt so I opened it up. After a close inspection I found the one bent push rod. After taking a rubber mallet to it, the tractor worked great again.
It surprised me what just one bad pushrod can do .
mjbrown
05-07-2006 07:55:57
I had a 9N that had to have the distributor shaft rebushed because it wobbled a bit from wear and the points would not open and close right. I don't know if that is the problem with yours but it's on of a bunch of possibilities. The 9N is long gone like a bad relationship. Revolver option should be reconsidered.
MarkB_MI
05-07-2006 07:27:26
Your problem has all the indications of one or more stuck intake valves. This can be confirmed with a compression check.
Semper Fi Guy
05-07-2006 04:30:26
I once had to solder up the float as it a hole in it....take the float off and put it up to your ear and shake it and listen, it's ok if you don't detect liquid in it, you may hear a little piece of solder rattling in there, don't adjust the float level unless you know how to do that properly.
marlowe
05-07-2006 03:27:43
sounds like a bad carb and check your engine oil if the carb is over flowing it will fill the crank case oil with gas and make it rum rich [black plugs] . as to what you have done so far is no more then regualer mantance and no real fixes . if timeing is on and you have fire and good air flow and good compression 100lbs. per then it fuel and sounds like to much and it is flooded or oil is full of gas
souNdguy
05-06-2006 22:11:20
Also.. only use wire core spark plug wires..
Soundguy
Bob
05-06-2006 21:37:20
Take a spark tester or a spare spark plug with the gap bent open to about 3/16" and verify that you have GOOD spark.
The puking back out of the carburetor point to:
1.) Firing order wrong.
Link loading="auto" style="width:auto;height:auto" alt="Third Party Image">">Link
2.) Burned or stuck valve. (Do a compression check.)
3.) Some of these engines had a fiber timing gear that would tear loose from it's hub and/or lose teeth, causing the camshaft and distributor to get "out of time" with the crankshaft, or not turn at all..
equally confused
05-06-2006 21:27:43
I had the very same problem with a 9N years ago. Turned out to be a bad coil. If not that I would always suspect the Marvel Carb. Even if it looks right, even if it worked great the night before. Rebuild it. I have had dramatic results this way. I always keep rebuild kits around for just such a moment. Pete
monomechanical
05-06-2006 21:35:22
 Re: At wits end trying to start 8n in reply to equally confused, 05-06-2006 21:27:43
Thanks Pete: I get pretty good juice to the coil. I'll rebuild the carb.
MN Bob
05-07-2006 06:25:19
 Re: At wits end trying to start 8n in reply to monomechanical, 05-06-2006 21:35:22
Not sure you got Pete's message about the coil. It wasn't the power to the coil, it was a bad coil. There is a test, but easiest way is to just slide in another coil. I have lost them on tractors and trucks. Good luck,
monomechanical
05-07-2006 10:18:33
 Re: At wits end trying to start 8n in reply to MN Bob, 05-07-2006 06:25:19
Thanks for the reminder, MN Bob. I did not type carefully, as you noted. I've got juice through the coil. I assumed since I've got spark to wires, even if some are weak, the coil is ok. Is this not correct? Does "bad coil" include "carries weak current" rather than no current? The coil is clean. Indeed, I polished the damn thing.
jim.
Old Pokey
05-07-2006 06:20:22
This may or may not apply here, but I know in my honda engines for water pumps and such, the spark plug will become "gas fouled". The ceramic stuff around the electrode will absorb a small amount of gas, especially if the carb allows too much gas in. Then even though I have very good spark, the spark is at the wrong time.
ron,ar
05-06-2006 21:25:34
go to N board, ask Dell or one of them guys. Its the fuel fire er sumptin. I know I am right about that!
