Tractor Talk Discussion Forum
ford 3500 Industrial shifter
Tommy B
05-08-2006 11:46:58
I have a 3500 Industrial ,it seems to have 2 rev and 2 forward gears plus a hi-lo,it has an H pattern. 2 forward gears up 2 rev. gears down.Is that normal?
williamf
05-08-2006 14:12:04
 You're not alone! in reply to Tommy B, 05-08-2006 11:46:58
I've got a 3500D TLB with that same transmission.
The owner's manual describes several different transmissions, but not that one. I thought for a long time that I had the only one. It works well; not synched at all, though. Full stop to shift, and if you ever let the clutch out in Neutral the gears take a while to stop spinning enough to put it in gear without a grind.
Wm
