Tractor Talk Discussion Forum
Sticky seat
Ohio Mike
05-08-2006 16:00:54
Need some ideas on how to get sticker adhesive off of tractor seat. I replaced two seats and on the back rest of each new seat was a sticker about 5 inches square. The stickers came off with no problems but now I have adhesive from the stickers on the seats that doesn't want to come off. Any ideas how to get it off without doing damage to the seat ?
Michael D.
05-08-2006 19:44:30
 Re: Sticky seat in reply to Ohio Mike, 05-08-2006 16:00:54
Try some peanut butter. The peanut oil is the best for removing stickey stuff.
Rauville
05-08-2006 18:48:35
I think Go-Jo hand cleaner would work.
jones in texas
05-08-2006 18:28:02
goo gone is great
RickSCt
05-08-2006 16:43:42
I would try rubbing alcohol.
RustyFarmall
05-08-2006 16:59:36
 Re: Sticky seat in reply to RickSCt, 05-08-2006 16:43:42
I'll second the motion for rubbing alcohol.
Midwest redneck
05-08-2006 16:16:51
I use WD-40 to get sticky tape off of stuff, and it works, I would just check it first for discoloration of the seat.
Mike in MI
05-08-2006 16:13:16
Mike,
I was told one time that WD40 will work? Is your seats vinyl? Try a small area to see if it works. I have used carb cleaner at one time it was stuck on there so bad I used lacquer thinner light amounts.
Try a small portion of it in a small area. May cause discoloration?
Good luck,
Mike
TimWafer
05-08-2006 16:07:14
Try "Goo Gone" available at grocery and hardware stores. Works great.
Bill in Ala
05-08-2006 16:05:32
WD 40
UncleTom
05-08-2006 18:51:47
 Re: Sticky seat in reply to Bill in Ala, 05-08-2006 16:05:32
I like to use parts cleaning solvent. It is petroleum and cuts glue better than anything i have tried.Drys in a few minutes after you wipe it off.
