Tractor Talk Discussion Forum
9n 3 point
stan frank
05-10-2006 12:11:02
my 3 point will not lower,what is my problem?
mn.Chuck
05-10-2006 16:56:13
 Re: 9n 3 point in reply to stan frank, 05-10-2006 12:11:02
Control Valve is stuck. If you take a round side
cover off(drain some oil down or tilt tractor to
the opposite side of cover removed)you will see
the two arms coming down from the top cover. They
cradle the valve that is not moving. A clip pin on
ea arm holds them to the moveable valve. Remove
them and try to gently tap the valve or pull out
and look for a small piece of brass or sliver that
is causing it to stick-loosen it up-best w/o removing it completely and it should work. Caution
if something is on 3 pt it may come down with a bang. Remove anything that is on the 3 pt. Chuck
