Tractor Talk Discussion Forum
need comp help no cd drive
chris sweetland
05-10-2006 18:02:41
ok i have a fairly expensine cd reader and burner drive in my comp my computer has been making "free space" latley and i thik it got rid of it does anyone know how to revive it its win xp office thanks chris
Mark - IN.
05-10-2006 19:31:59
 Re: need comp help no cd drive in reply to chris sweetland, 05-10-2006 18:02:41
If your computer is arbitrarily outing drivers and files and stuff in its quest to free up space, and not your idea, you've got a much larger problem and need to find it (virus? hard drive?).
But if its you freeing up space and mistakenly outed a driver, you'll need to go through the process priviously stated, and have to get the driver off of... where ever it came from (OS CD supplied with PC? Seperate CD for the drive? Online from the manufacturer website?). You may be able to get it back from a system restore, but once you've outed the driver, that usually doesn't work - never has for me. And just because it quit working doesn't mean thats what happened. Have you added software or a device since the last time it worked that you can recall? You may have a device address problem/conflict. If thats the case, try removing it by using the "remove" program from the install CD - works better than "remove" from add/remove programs through control panal, then do a defrag.
Job one, go through device manager as suggested, and see what you've got.
Mark
williamf
05-10-2006 18:19:09
Try opening Control Panel, click Add Hardware. Have your computer look for uninstalled hardware.
If not that, it might help to do a System Restore.
I've screwed myself into having to do this several times. So far I haven't had to take the box to the shop.
Click on Start, Help and Support, System Restore.
Select the most recent restore point that you think the cd burner was working. If you ask people you don't know for advice we can't be held responsible if you take it.
Good Luck,
Wm
