Tractor Talk Discussion Forum
farmall H with no 5th gear
bob the farmall
05-12-2006 08:45:54
did some of the early H's only have a 4 speed trans?
I have a Sn #1836 with no road gear 5th
bob the farmall guy
05-16-2006 05:35:23
 Re: farmall H with no 5th gear in reply to bob the farmall guy, 05-12-2006 08:45:54
thanks for the info I will try removing the bolt as my sn is 110819 in stead of 1830
Leroy
05-12-2006 14:31:25
A lot of 42 & 43 & 44 models were like that due to the war and no rubber tires avaible
Wild Bill
05-12-2006 08:49:59
Bob, yes, the early H's on steel wheels had no 5th gear, or they had a bolt in the tranny top cover to lock the shifter from going into 5th gear.
Dean Barker
05-12-2006 21:05:10
 Re: farmall H with no 5th gear in reply to Wild Bill, 05-12-2006 08:49:59
Wild Bill is right. One of the top cover bolts was extra long to block the shifter from going into 5th. Replace this bolt with a shorter one and you will have 5th.
