Tractor Talk Discussion Forum
Case 430 - Need to bleed hydraulic system with new
paul in on
05-12-2006 14:30:28
If I hook up new hoses and cylinders to a Case 430 for a loader, will the system bleed itself? Also, will I need to get a reserve hydraulic tank for the loader? Paul
Ken L
05-12-2006 15:48:09
 Re: Case 430 - Need to bleed hydraulic system with in reply to paul in on, 05-12-2006 14:30:28
No, you will not have to bleed the new hoses. Just cycle everything a few times and the air will work it's way out. Be sure to check the oil level after you do this. You should not need an extra tank for hyd oil to run the loader. We had a 430 once. Bought it new in 68. Had a loader on it. I'm sorry to say that it was the worst tractor that I've ever had the displeasure of driving. Good luck.
