Tractor Talk Discussion Forum
transmission pressure
ballast
05-13-2006 15:15:59
I bought the 4610 ford tractor...It runs great...but I have a question...after I run it for a while the transmission builds up pressure...is this normal ??? when I pull the dip stick hot air blows out...help needed...thanks robert
Roy Suomi
05-14-2006 04:08:58
 Re: transmission pressure in reply to ballast, 05-13-2006 15:15:59
I think I would drill and tap the fill plug on the rear housing and install a breather to keep from presurizing that area....
RAB
05-13-2006 22:33:24
Near everything will increase in size when heated and unrestrained. Gases the most. If they are contained at the same size, pressure must increase instead.
Nothing different with a tractor engine, gearbox or whatever. So it should be vented to atmosphere. If not, the pressure will eventually vent itself - through the seals. Also with your tractor hydraulics you may just be letting a large quantity of fluid back in there from hydraulic cylinders as well.
Regards, RAB
