Tractor Talk Discussion Forum
Jacobsen Mower Problems
Wayne in Tx
05-15-2006 09:36:46
I have a Jacobsen mower with a 3 cyl (D950 BW) Kubota engine. Recently, while running, it has started to drip fuel/oil out of a hose that attaches to the valve cover (like a crankcase vent). Doesn't seem to be any other problems. I am curious as to what would cause this and how to correct it.
Shannon from ohio
05-15-2006 18:02:57
 Re: Jacobsen Mower Problems in reply to Wayne in Tx, 05-15-2006 09:36:46
""Words of wisdom"" Check your oil level after it has been shut off for a while. Possibility of an overfilled crankcase caused by seal failure inside the injector pump, pumping diesel fuel into the oil.If left unchecked it WILL cause bearing DEATH caused by dilution??
