Tractor Talk Discussion Forum
Wheel seal
Darin in Nebras
05-16-2006 09:45:06
Hello everybody. I was wondering if anybody here has torn off the rear wheel on like a international 240 utility or something that might be similar? I can get the wheel off no problem but the hub is stuck on there. Is there a keeper ring or anything that holds that on? Would it be smart to apply heat to it or will that cause more problems? I would like to change the wheel seal on that side cause it leaks. Thanks for your time. Darin
Tom N OK
05-17-2006 05:44:21
 Re: Wheel seal in reply to Darin in Nebraska, 05-16-2006 09:45:06
Hi Darin Good to meet you at the Steam show in Pawnee. Too bad it was so rainy. I don't know much about your problem but I know if you go to the search block at the top of the farmall page and type in `axle seal' there are some 240's there and there was a pretty good one with some detail on a 300U don't know how similar they are but hope this helps.
Tom
Darin in Nebraska
05-18-2006 09:31:20
 Re: Wheel seal in reply to Tom N OK, 05-17-2006 05:44:21
Well hey there buddy. Yea, it also nice to met yea. I have not met anybody off of this site before. I was surprised when you came and said that you were who you are. Caught me off guard. Yea, I will have to check that out and see how that helps. I have a parts catalog for my tractor and the only clip I see holding anything in is futher back in the rear end and it holds the axle in. Thanks for the post and take care bud. Talk to you again. Darin
