Tractor Talk Discussion Forum
hoss power?
Tim Shultz
05-20-2006 07:17:37
whats the horse power of a farmall M? what about my case 611B? I was told the case has about 64 HP.. but what about the M? need to clear this up.. buddy of mine said the M has more HP than my case.. we are BOTH just guessing though..
THANKS!
T.S
Keith-OR
05-20-2006 09:24:40
 Re: hoss power? in reply to Tim Shultz, 05-20-2006 07:17:37
Tim, here is where you want to go to get the actual tested draw bar HP and belt or pto HP out put.
Keith & Shawn
Tim Shultz
05-20-2006 07:31:51
 Re: hoss power? in reply to Lou, 05-20-2006 07:24:44
THANKS FOR THAT SITE LOU! seems my case has 37 drawbar HP, 45 PTO
M has 25 drawbar, 31 PTO
T.S
RAB
05-20-2006 11:19:44
 Re: hoss power? in reply to Tim Shultz, 05-20-2006 07:31:51
A lot depends on the tyres, ballast and other factors as to your actual drawbar power.
Even PTO power can be way off for actual examples 40+ years later.
One large factor could be is one of them very tired and the other had a fresh rebuild? Another is have either been fitted with oversized pistons and liners or high compression pistons?
I would not bet any money if both were put on a dyno, unless I knew more....
Regards, RAB
Regards, RAB
JMS/MN
05-20-2006 08:52:34
If using tractordata, get a second opinion. There are an awful lot of mistakes in the specs they list.
Lou
05-20-2006 08:59:21
 Re: hoss power? in reply to JMS/MN, 05-20-2006 08:52:34
Yes ive wondered about that. Seems ive read somewhere the M was in the mid 30s. Whats a better source of info?
Tim Shultz
05-20-2006 08:58:13
really? any other site that I could look it up on? thanks!
Tim Shultz
old
05-20-2006 09:07:49
 Re: hoss power? in reply to Tim Shultz, 05-20-2006 08:58:13
Best way I know to find the real HP of a tractor is to go to the neb test web pages. I don't have the address for it but if you do a search for neb test you should find them. Thats about the only way to find what is real HP of the tractors since the companys liked to pad the HP that there tractor had. Of course HP isn't every thing. For instance I have an Oliver 77 and a ford 841. The 841 is rated at 45HP and the Loiver is rated at 38HP but the oliver will pull circles around the ford
Lou
05-20-2006 09:20:02
 Re: hoss power? in reply to old, 05-20-2006 09:07:49
Ive done about 5 different serches for the Nebraska site, cant find it?
old
05-20-2006 09:38:44
 Re: hoss power? in reply to Lou, 05-20-2006 09:20:02
Don't know what to say, thats how I found it years ago. You might try this. http.//www.reunionofthepast.8m.net/Nebraska_Test I took that form the bottom of a few pages I printed out years ago so I would have that info handy at all time
Lou
05-20-2006 09:46:09
 Re: hoss power? in reply to old, 05-20-2006 09:38:44
Still cant get it to work. But Im no expert on this computer.
old
05-20-2006 09:56:17
 Re: hoss power? in reply to Lou, 05-20-2006 09:46:09
Just for the heck of it I just tried to do a search for the neb test my self and came up with something like 293,000 differant sites. I'm sure gald I printed out those pages years ago because its not easy to find it any more.
