Tractor Talk Discussion Forum
MF #3 HAY BALER NEED HELP
BUFFALO
05-20-2006 19:27:49
HAVE A MF3 BALER THAT THE KNOTTER TIES GREAT BUT KNOT WILL NOT RELEASE FROM KNOTTING FINGERS SO WHEN 2ND ONE GOES TO KNOT THEY GET ALL MESSED UP. TRYED ADJUSTING SPRING TENSION IN BOTH DIRECTIONS, BUT THAT DIDN'T HELP. CAN PRY FINGERS OPEN AND LET KNOT OUT AND BALE COMES OUT FINE.
BUFFALO
05-26-2006 20:11:53
 Re: MF #3 HAY BALER NEED HELP in reply to BUFFALO, 05-20-2006 19:27:49
HEY, THANK YOU ALL FOR THE HELP. I HAVE BALER WORKING NOW. I KEPT RUNNING BALES IN IT AND ADJUSTED AND KNOW IT IS WORKING. I THINK ALL THAT WAS WRONG WAS THE FINGERS NEED WORKED OUT REAL GOOD TO GET THE SLICK SHINE BACK TO THEM. I RAN 10 BALES THRU IT FOR ABOUT 50 TIMES THAT SHINED THINGS UP. THANKS AGAIN
PS. JJ IF YOU COULD GO AHEAD AND SEND ME CUT SHEETS ON TIEING AREA THANKS
agrogers
05-21-2006 09:47:57
You probably need new bill hooks. I replaced mine on a #10 (same knotters) when it wouldn"t let go of the knot and it ties fine now. It wouldn"t hurt to make all the adjustments outlined in the operators manual as well.
JJ. in B.C.
05-20-2006 22:42:18
Sounds like timing may be out, do you have the manual for the Baler ?, if not send me your e-mail address and i will scan the relevant pages for you.
JJ.
