Tractor Talk Discussion Forum
sos 671transmission fluid and replacement air
gil cox
05-21-2006 09:16:17
What is the best trasemission fluid for the 671 SOS? Where can I find a air cleaner tube the proper size for the 671 SOS? Thanks Gil
RodInNS
05-21-2006 14:28:38
 Re: sos 671transmission fluid and replacement in reply to gil cox, 05-21-2006 09:16:17
Ford/NewHolland 134D is the correct oil for your 671 SOS. Could you use some off the shelf rubber hose for an air cleaner tube, or are you looking for the correct metal tube? Rubber could probably be found at any auto parts store. The tube; probably from NewHolland, although I wouldn't swear on that either.... You could no doubt find the tube at many a salvage yard scattered throughout the country... HTH.
Rod
Roger Scott
06-22-2006 13:34:04
 Re: sos 671transmission fluid and replacement in reply to RodInNS, 05-21-2006 14:28:38
Any idea wht a 1960 Ford 671 is worth? Gas, 2001 hrs on the clock. Runs and is used regularly to cut a field with a bush hog on it.
