Tractor Talk Discussion Forum
Leaking Sediment bowl
DZ
05-21-2006 16:39:54
Are there packings available for a leaking sediment bowl? I hate to replace the whole thing for a 25¢ packing? Also could a person slip an O-Ring inside to help it seal when I shut it off. It never seals really well.
Or should I just go out and buy a new $24 sediment bowl.
Dave Sherburne NY
05-21-2006 19:01:53
 Re: Leaking Sediment bowl in reply to DZ, 05-21-2006 16:39:54
I bought one at TSC for $22 and could not get it to
stop leaking . Gave up and bought one for $15 at the local auto parts store and no leaks. If you have an origional, I would take the bowl to Napa and get
new screen and gasket. If it leaks around the valve
unscrew the nut take the valve out, and put a graphite coated string packing inside the nut.
You can get this from most hardware stores. Its the
same thing used in older kitchen faucets.
GeorgeH
05-21-2006 18:26:27
You can get just gaskets at NAPA. Take your bowl with you to be sure you get right size.
GeorgeH
05-21-2006 18:25:56
HAS
05-21-2006 18:25:07
Yep, better to just replace it. Most don't have packing - they are designed to be full open/full closed. When full open they back-seat to prevent leakage.
BMAN
05-21-2006 17:59:19
I've had good luck with o rings
Tim Shultz
05-21-2006 17:42:34
to me, once they start leaking they are about shot.. I would just go out and spend the 24$ at tsc or what ever.. and after you get a new one spray some WD-40 on it once a month or more..
T.S
