Tractor Talk Discussion Forum
H hydraulics
bob the farmall
05-22-2006 05:18:45
I have a 43 Farmall H and the belly pump doesn"t opererate any advise to fix it?
RustyFarmall
05-22-2006 06:35:27
 Re: H hydraulics in reply to bob the farmall guy, 05-22-2006 05:18:45
First, the clutch pedal has to be up in order for the pump to work. Second, remove the inspection cover located under the tractor and behind the pump, take a look up in there and see if the coupler is in place. Also, the pump reservoir needs to have 6 quarts of motor oil in it. If it still doesn't work, you need to provide a few more details.
bob the farmall guy
05-23-2006 05:27:31
 Re: H hydraulics in reply to RustyFarmall, 05-22-2006 06:35:27
thanks I'll try that
