Tractor Talk Discussion Forum
Gap setting for relay needed ......
Way Up Here
05-23-2006 20:20:50
I have a tractor here with an Autolite 6 volt, 3rd brush generator with the single-coil relay mounted on the generator. The point gap appears pretty wide and I am wondering if there is a recommended gap setting for these relays. Thanks for any responses.
J Schwiebert
05-24-2006 07:19:34
 Re: Gap setting for relay needed ...... in reply to Way Up Here, 05-23-2006 20:20:50
That relay is just the cut out and has no affect on charging output. All it needs to do is close to connect the generator in the circuit once the generator build the right voltage and then unhook the generator from the battery when it is slowed down. If you are having charging problems I can send you a trouble shooting chart for the Oliver colletocs. It will also work for your Auto-Lite. Questions?
noncompos
05-23-2006 21:57:58
FWIW: have a 46 Motor Car repair manual; Auto-lite regulator section doesn't seem to have any text on the old one-coil cutout relays (all on two and three coil) BUT in the regulator spec pages does have tables for "Auto-Lite Cutout Relay Specs.."...lists five CB 4000's and two CBA 4000's; all have ".010-.030" (exactly like that) Armature air gap and ".025-.035" (exactly like that) Point gap...sorry no dig camera...also shows Cut-in voltage "6.5-7.25" for all, and Points open, amperes discharge ".5-2.5" for the CB's and "1.5-4.5" for the CBA's; that's all there is..have no idea if it applies to your unit or not. Manual covers 35 thru 46, if that helps. Good luck.(Having DSL problems here, may not be able to receive questions but feel free to try.
