Tractor Talk Discussion Forum
Ford 6600 clutch
Lestuer
05-29-2006 11:56:33
after hooking up the mower to the PTO I steped on the cluth pedal to engage the clutch and the pedal went to the floor and would not engage the clutch. I have had no prior problems with it. Did the clutch just go out or did some single part break, or could there be another explaination?
RodInNS
05-29-2006 14:53:10
 Re: Ford 6600 clutch in reply to Lestuer, 05-29-2006 11:56:33
If the external linkage is intact, then I would suspect that the pinch bolt that retains the clutch fork to the cross shaft has broken. If not, then something's wrong in the PP assembly. If it's not external, it's split time.
Rod
