Tractor Talk Discussion Forum
saving em from the scrapper
Nebraska Cowman
05-29-2006 20:38:00
So how far do you go? here is an RD7 that would run with a little tinkering. What do these beasts weigh? Bought a cute little 22 that is in pieces and a few other wheel tractors tonight. Now I gotta get busy and haul them home.
third party image
Billy NY
05-29-2006 22:45:34
 Re: saving em from the scrapper in reply to Nebraska Cowman, 05-29-2006 20:38:00
RD-7, either a 5E or a 9G serial number, looks like a wide gauge 74" center to center of track.
Next series up, D7, the bare tractor is approximately 24,000 lbs.
This tractor (would love to see more photos of it)has what appears to be an R-7 LeTourneau Power Control Unit, P.C.U. but uses what also appears to be an early overhead ridge beam with block and sheaves for a cable blade, the P.C.U. is defintely LeTourneau, but the rest of it could be early Letourneau, or another MFR., possibly shop fabricated, but I have seen a similar set up on a Cat Sixty, you don't see too many dozer kits on those, but the ridgebeam drops down like yours does towards the nose.
I see the blade trunions, right above them, is what looks like the mount for what most RD-7/D-7 9G serial number tractors have for the LeTourneau overhead ridgebeam which is one main group of a dozer kit offered by LeT. then. The 2 supports are like a Y pivot on the mount, and must be at a 45 deg. angle to span each way to the front and the back.
This tractor is nice, looks complete, has all the track adjuster covers, original spoked idler and sprocket, the undercarriage could be in decent shape, big adjuster under the cover, you can measure that to see how much adjustment is left, they look tight, old style top rollers, and it's got rock guards on the bottom rollers(few more pounds) The track pads look decent.
Starting engine is complete, there are some things to know about these, keep the oil very clean in them change often, also watch/sniff for gas leaking into the crankcase thinning the oil, (there are ways to prevent this) it's a splash lube 24HP low tech flathead motor, they like gas, and spark, the magneto is either an Eismann or American Bosch,maybe Wico, built for Cat. Another thing comes to mind when foolin with these and trying to fire one up that has sat, the main engine needs to spin to circulate coolant through the starting engine, if not it will overheat. They are a bit expensive to re-build, but there is no substitute in the bitter cold for conditioning the diesel to fire.
You may have to fool with the main engines fuel system, if it's sat a long time, some times the injector pump rack sticks, you need to drain the diesel tank, change the filters, all the old school diesel things right up to the injectors to see if you are getting spray etc. Somtimes you get lucky and don't have to deal with it. You can take a tractor tire tube and cut an 8"-10" round section around the valve and use it clamped over the tank neck to pressurize the system, flush, bleed etc. only need a few lbs. of pressure.
That is a nice RD-7 in the rough, I'm glad you saved it from the torch! Very handy to have on a farm once in running condition.
Not sure if it has the blade, but it could weigh up over 26,000 lbs. but not over 30,000 lbs.
The Twenty-Two is probably under or around 10,000 lbs.
Nebraska Cowman
05-30-2006 03:36:09
 more pics in reply to Billy NY, 05-29-2006 22:45:34
here's a couple more. There is a blade for it but I didn't look it over, I assumed it was shop-built and not worth messing with. The little 22 is pretty much beyond help unless somebody realy likes hard work.
third party image
third party image
third party image
third party image
Billy NY
05-30-2006 07:08:27
 Re: more pics in reply to Nebraska Cowman, 05-30-2006 03:36:09
That lift set up from the PCU to the front with the sheaves, looks unique, possibly a LaPlante- Choate, as might be the blade. It looks manufactured, I'd take a close look at the blade and see if there is a MFR tag on it, good chance it goes with the rest, it's possible someone wanted a blade on the tractor and put it together from factory components. If it's a factory built one, it sure makes the tractor a little more desirable and unique, there are'nt a lot of those LeTourneau era cable dozer blades around any more. I've never seen that configuration before, check on the ACMOC and ACME websites, post a few shots, they'll like that tractor.
The head has been off that 22 for awhile, ( I hate when people do that- at least pack er with grease and cover it up ) the track pads look new, have to wonder if the rest of the U/C is that new, if it is someone will want it as a parts macchine. I can't imagine getting those pistons out, I'm not sure if that gas engine is sleeved, what a challenge to fix that one, kind of a shame when they're left with a good U/C, most of the other work to do on these is not as expensive as replacing U/C parts and usually worth doing if the U/C is good.
ACME: http://www.antiquecaterpillar.net/ACF_v2/index.php?
