Tractor Talk Discussion Forum
Injector setting for John Starnes
NC Wayne
05-30-2006 15:23:06
Hey John, sorry it took me so long to get back to you. I checked what books I've got and the only injectors showing as being used in a 2-71 are 71N5, N55, 60, and 70. The only place I found the N65's showing as being used were with the 4 valve heads on the other 71 series engines that were using advanced cam timing. In these engines the N65 had a setting of 1.484.---- Most of the books I've got are older, except for the Field Service data book which is only a few years old. I would have thought one of them would have showed me something but I may have missed it, it may fall in a time frame I don't have covered, or someone may have used different injectors in yours before you got it trying to gain a few more HP. Beyond that I can't tell you anything else except I'll have to make a call and find out. If you've got the serial number off the engine I can use that to find out exactly what injector was used in it from the factory and pretty much anything else you want to know. Sorry I couldn't have been more help right off. There are just so many different combinations it's impossible to remember them all so I don't even try, I just know where the stuff is in the books and know who to call if it isn't there. If you can get me the serial number I can find out just about anything you need to know. Just let me know.
