Tractor Talk Discussion Forum
replacing carb on JD 1010
lloyd in sc
06-03-2006 06:40:13
Been fighting a carb on my 1010, any advice about the diference between a rebuilt marvil schriver (spelling?) or a new zenith? The price is about the same & it's a work tractor. Thanks lloyd
RustyFarmall
06-03-2006 13:38:24
 Re: replacing carb on JD 1010 in reply to lloyd in sc, 06-03-2006 06:40:13
Unless the present carnuretor is broken or cracked there is no reason it cannot be rebuilt to be just as good as a new one.
Glen in TX
06-03-2006 09:49:17
The new Zenith is a better later design but none will work well with old cruddy gas and dirt in tank. For the JD 1010 & 1020 the Zenith 12566 should be a good direct fit bolt on but the Zenith 14996 is a universal fit carb with universal throttle linkage that has to be made to fit once you get the carb. The rebuilt Marvel Schebler should also be a ready direct bolt on change and should work well if it was rebuilt correctly. Parts are still readily available for the M/S TSX carbs. Some older M/S carbs were a poor design but the TSX was a good one.
Bob
06-03-2006 08:39:32
What's wrong with the old carb that can't be easily remedied?
lloyd in sc
06-03-2006 20:46:43
 Re: replacing carb on JD 1010 in reply to Bob, 06-03-2006 08:39:32
Well, the top half is a TXS809 & the bottom half is a TXS 34. I broke the shaft in the old one & cobbled this one together. It worked but now doesn't want to shut off gas flow (float is free)... just wandering whether a rebuild by an actual tech might solve most of my problems...
msb
06-03-2006 06:44:43
Buy the Zenith.Nuff said.
