Tractor Talk Discussion Forum
JD 2640 closed system hydraulics or open
Willy P
06-05-2006 19:24:59
On my JD 2640 we hooked up a cross valve for the batwing mower and do I need the power beyond plug or which of the plugs do I need to put in it? The mower creeps up and after awhile the hydraulics stop working and we disconnected the 3 spool valve and the hydraulics work find,maybe we put the wrong plug in it? Any help would be appreciated.
DaveH IA
06-06-2006 03:53:34
 Re: JD 2640 closed system hydraulics or open in reply to Willy P, 06-05-2006 19:24:59
It's closed center--also where did you dump the return oil? they make a ported hyd. filter cover to hook the return line to that puts the return oil back in the charge side to keep more oil going to the front pump---can drill and tap 1/2 pipe thread in your old cover and save buying the one from deere
Willy P
06-06-2006 10:14:37
 Re: JD 2640 closed system hydraulics or open in reply to DaveH IA, 06-06-2006 03:53:34
Yes I do have it dumping back into the filter but I am not sure if I have the right plug installed in the valve for closed center system, my dealer was not very intelligent about this. Thanks
matthies
06-05-2006 20:07:59
Your tractor has a closed center system, so you need to make your spool valves a closed system also, usually by changing a plug. The last cross valve I bought was a open center and I had to buy the closed center plug. chris
