Tractor Talk Discussion Forum
Weed question
MarkinMo
06-09-2006 05:39:39
Anyone ever dealt with a weed called dodder? It looks like spaghetti and it classified as a parasitic weed. Sounds like some nasty stuff. I got some introduced in an alfalfa/lespedeza field that we planted this spring. I think the seed came from the lespedeza we bought from local co-op (I'll never buy un-certified seed again!). Does anyone know how to control this stuff without destroying the good stuff? I just mowed the field with my haybine but the stuff is so low to the ground it didn't seem to get much of it.
nballen
06-09-2006 07:47:22
 Re: Weed question in reply to MarkinMo, 06-09-2006 05:39:39
Dodder is a nasty agressive invasive weed!! Please don't ignore this weed!
In SE Oregon / SW Idaho, I have seen attempts to dodder in irrigated fields by burning. Use a propane weed burner and burn out the affected area. Of course this will damage the host plants (your crop) but this damage is preferrable to the alternative - large-scale crop loss.
Ten-to-fifteen years ago, burning was acceptable even in fields of certified alfalfa or clover seed. I don't know about now.
sammy the RED
06-09-2006 06:25:05
Dodder, an annual plant that consists of thin thread-like stems that are orange in color which attach to a host plant, belongs to the dodder (cuscutaceae) family, which includes many species. At one time dodder was classified in the morning glory family. Dodder is a true parasitic plant. Unlike other parasitic plants such as mistletoe, which have green leaves, only extract water and nutrients from host plants. Dodder has no leaves and must extract carbohydrates from the host plant.
Dodder produces small clusters of white to pink flowers in the early summer. Dodder spreads primarily by seeds which have the capability of surviving in the soil up to sixty years. When dodder seed germinates, establishment is dependent upon host plant availability. If a host plant is not within 1 - 3 inches of the initial germinating seed the seedling will die. When the dodder seedling emerges, it develops a small ineffective root which can support the seedling for only a couple of days. Upon germination, the small dodder seedling sways around in search of the host plant. When a host plant is contacted, the dodder coils around the host in a counter-clockwise direction. Small sucking appendages called "haustoria" are produced that penetrate the host plant and extract food. Once the haustoria begin to extract food, the small initial root dies. Dodder can grow up to 3 inches per day and continually produces new haustoria to drain the host plant of nutrients.
Dodder is found throughout North America.
Cultural Practices: ..... Dodder is best controlled through establishment prevention by using clean seed. ..... Ornamental beds should be kept clean of seed-producing plants. Once dodder becomes established, eradication is almost impossible. Mechanical removal can be attempted, but once dodder has produced the haustoria it is near impossible to avoid damage to the host plant. If dodder has germinated and has attached to a host plant, removal of both is recommended to eradicate.
Herbicide Use:
Use of pre-emergent herbicides is the best chemical approach. These products must be applied prior to the germination of the seed as the small seedling root will drop off once the haustoria has formed. Dinitroanaline herbicides have been reported to be effective. Dichlobenil has also shown good results. Read all labels to ensure that the herbicides can be used around the host plants. Glyphosate has shown results as a postemergent herbicide, but its use is limited as it will also damage the host plant. Phenoxy herbicides have only shown limited control and again injury to the host plant can occur.
Dave H (MI)
06-09-2006 17:01:33
 Re: Weed question in reply to sammy the RED, 06-09-2006 06:25:05
Wow....but you forgot your bibliography. Aren't you supposed to have a bibliography when you write a report like that? :-)
Dave H (MI)
06-09-2006 17:01:26
