Tractor Talk Discussion Forum
Allis Carbs
Chad Preuss
06-09-2006 08:23:01
Does anyone have a good source for adjusting the carb on a Allis WC and WD?
Coloken
06-09-2006 10:14:33
 Re: Allis Carbs in reply to Chad Preuss, 06-09-2006 08:23:01
Run the engine at about 2/3rd speed. Close the main jet untill it starts to run ruff. Open back a wee bit. Idle engine, do the same thing with idle jet. Under full load in the field, you might have to redo the main jet a bit.
wilman
06-09-2006 09:12:27
What type of carb? Zenith or MS? What type of adjustments do you need to do?
Wil
Chad Preuss
06-09-2006 09:53:54
 Re: Allis Carbs in reply to wilman, 06-09-2006 09:12:27
Zenith.
YouKnowMe
08-18-2006 10:44:08
 Re: Allis Carbs in reply to Chad Preuss, 06-09-2006 09:53:54
Idle: Lean down until you get a good clean idle
High speed: Under load in the field, lean it down until it starts to break up, and then richen up 1/8 to 1/4 turn.
By the way, your truck looks way better now that it is fixed...
Mule
