Tractor Talk Discussion Forum
hydraulic cylinder
merle dinslage
06-10-2006 07:00:04
I have a Super M International. It has a one way pump. I bought a tandem disc which has a two way cylinder. I was told I could use the two way by putting a breather plug and only use on hose. All that happens is the oil blows out the breather plug. Can anyone give me suggestions or is it not possible to use the two way cylinder with a one way pump?
Joe(TX)
06-12-2006 05:33:18
 Re: hydraulic cylinder in reply to merle dinslage, 06-10-2006 07:00:04
It is probably blowing out the oil that is already in the cylinder. If it continues the seals in the cylinder are bad.
You could run the other line back to the reservoir.
Jimmy King
06-10-2006 08:42:08
The pump is not a one way the control valve is a one way, you can use a breather on the dead end of the cyl, or you can replumb the pump with a two way valve. The one way will work unless you want to pickup the wheels to add weight to the disc.
IaGary
06-10-2006 07:11:05
First of all did you remove the correct hose?
If you did the cylinder will blow all the oil out on the first cycle of the cylinder.
If it continues to blow out oil the seals on the piston are bad.
If done right it should work ok.
Gary
