Tractor Talk Discussion Forum
Hydraulic help
Devin Sparks
06-10-2006 16:28:12
Hello,
I am putting a new hydraulic cylinder on my JD BWA disc harrow. The old one has died. I went to Agri-Supply here in NC and picked up a new one. I put it on and hooked up the lines. One of the lines felt like it stripped when I tightend it up. I hooked to tractor and raised and lowered it a couple times and then BOOM..Fluid everywhere. So I take it back and get another. The original had the lines coming straight off the cylinder. The new cylinders come off to the side. I am using 90 degree fittings so they will be inline with the cylinder.Guess what, I have had the same thing happen with the second cylinder.What am I doing wrong.The lines are 1/2 inch. The fittings feel a little loose and have some play. I tried all other sizes and the ones that I have are the only ones that fit. I will tell you that it is a Grizzly clyinder(Import) if that matters. Any help would be great.
Thanks
Devin
RodInNS
06-11-2006 18:31:00
 Re: Hydraulic help in reply to Devin Sparks, 06-10-2006 16:28:12
You need to find out what fittings you have. The cylinder might have NPT thread, or O-ring boss (ORB). Your hoses could be NPT, ORB, or JIC, none of which will interchange properly. At a guess, I'd say you put an ORB fitting into a NPT hole. If you don't know what's what, take the whole mess with you to somebody that does. It's not easy to explain the differences between thos fittings without looking. HTH.
Rod
Devin Sparks
06-13-2006 16:37:23
 Re: Hydraulic help in reply to RodInNS, 06-11-2006 18:31:00
Thanks to those who helped with this problem. I went back and found someone to help me and got the right parts.
Devin
Doug in IL
06-10-2006 17:38:26
The elbow fittings are probably NPT pipe thread. The cylinder ports are probably threaded for the o ring type SAE threads.
Midwest redneck
06-10-2006 16:56:20
It sounds like you are using a pipe fitting in place of flare or something. I would look into inspecting what you have before you strip another set.
