Tractor Talk Discussion Forum
801 Ford Tractor
Larry Lathey
06-10-2006 16:33:07
Anyone have a clue if they made a blue 801 Ford tractor. I think it is a 58 model. Is that the real color it should be.???
F3eron
06-10-2006 18:22:09
 Re: 801 Ford Tractor in reply to Larry Lathey, 06-10-2006 16:33:07
No Ford didn't paint the 801 blue. Someone probably painted it blue to look like the newer Fords
Larry Lathey
06-10-2006 18:34:27
 Re: 801 Ford Tractor in reply to F3eron, 06-10-2006 18:22:09
Did they make an 801 Industrial Ford , I think this one is a 58 model. How do you tell for sure which model you have in the 801 series ?
Feron
06-11-2006 09:41:56
 Re: 801 Ford Tractor in reply to Larry Lathey, 06-10-2006 18:34:27
Yes Ford made the 801 in an industrial model. Ford made a light and heavy industrial . The heavy would be an 1801. on the light duty the front axle is a straight axle no adjustment.
On the left side of the tractor behind the starter there is a flat spot on the clutch housing that is were the serial # and the model #.
