Tractor Talk Discussion Forum
Cummins questions
Sam F.
06-12-2006 22:28:00
I know lots of you use Dodge's with the Cummins engine. I have a 2001, 3500 that needs a power boost. I pull a 30 foot gooseneck and put 2 or 3 tractors on it. 15,000# behind the Ram. When I hit a slight incline, just an overpass I bog down. All I have done is add 4 inch exhaust and K&N filter. What's next ?? Any Cummins sites that answer these type of questions ??
JDGnut
06-13-2006 10:39:59
 Re: Cummins questions in reply to Sam F., 06-12-2006 22:28:00
Also try the dieseltruckresource.com page.. its free to register... Its time for some guages.. and aftermarket power box... or a power box that has gauges... JDGnut
Tim Shultz
06-13-2006 05:50:11
my sisters boyfriend has a 2004 dodge 3500, he has 6 inch bully-dog pipes K&N air filter and a bully-dog power pup down loader.. it can now pull ANYTHING with ease.. has so much torqe that he has broke three U joints.. so if you are looking for more power that is the way I would go.. just make sure you get the right gages so you don't over heat.. it won't be cheap either.. around 2,000 for all of it. just my .02
Tim Shultz
the tractor vet
06-13-2006 05:42:14
Well to this question , first off what is your total gross ?? now you say ya got 15000 now that does not include the weight of the truck or the trailer so you are grossen more like 30000 or better . Ya got to keep in mind that hey this is a pick up not a semi and what are the gear ratio 's and just adden a 4 inch exhaust and a K&N filter did noting but cost money . And at stock off the show room floor it may run good and it may not . Have you ever had it to cummins to be PUT INTO SERVICE ??? have ya ever run the overhead had the pump checked . My 95 Dodge was a dog when i got it as the guy before me never did anything to it but run it was never in to cummins or Dodge to have the valves adjusted or the pump checked or set . after i did the overhead and set the pump day and night differance. These are a true DIESEL and they require reg. maintance .
Joe-Bob/IN
06-13-2006 04:41:44
I replied to your question above so I would say you are low on power due to dirty injectors. I would also suggets boost and pyro gauges to keep tabs on the engine.
TImWafer
06-13-2006 04:16:37
Heres the place to go. You have to be a mmeber to post a question or do a search but you can browse the forum.
jlmtractor
06-13-2006 04:14:48
my dad use to pull a 30ft fifth wheel camper with a 1998 3500 with a cummins and it would bog down going up hills but we figured it was just because it hadnt down shifted yet
GeorgeH
06-13-2006 03:29:08
Cummins site used to reply to questions. Haven't tried in a year or so.
