Tractor Talk Discussion Forum
Dual Chain
JMS/MN
06-14-2006 12:24:57
third party image
Haven't lost a dual J-bolt in over thirty years since I came up with this idea. Rings are cut from old springs. Also use the rings to route hydraulic hoses.
MN Bob
06-14-2006 18:49:38
 Re: Dual Chain in reply to JMS/MN, 06-14-2006 12:24:57
Like they say, an ounce of prevention-- What sort of spring did the rings come off of? I could use a new hose guide/keeper on a couple implemnts. Bob
JMS/MN
06-14-2006 20:27:34
 Re: Dual Chain in reply to MN Bob, 06-14-2006 18:49:38
Lost a couple J-bolts many years ago- had only one come loose since, and it stayed with the tractor. Springs are from a field cultivator- one yields many perfect circle rings. Hard to make them by hand. I used to torch the spring lengthwise, but now cut them with a chopsaw.
Bill(Wis)
06-14-2006 17:25:02
Is that some sort of John Deere you have there? Don't think you painted Allis wheels yellow because they don't look like Allis to me. Maybe a D19 though.
JMS/MN
06-14-2006 20:21:51
 Re: Dual Chain in reply to Bill(Wis), 06-14-2006 17:25:02
This one's a JD 4240- grew up on AC, farm mostly with JD, but still have both.
Don-wi
06-14-2006 12:31:44
You have a problem with them coming loose? We"ve never had one fall off that I"m aware of, just gotta get on them a little with the wrench
Donovan from Wisconsin
Allan In NE
06-14-2006 12:35:43
 Re: Dual Chain in reply to Don-wi, 06-14-2006 12:31:44
Yep,
Tighten 'em til they squeal. Never heard of one comin' loose. :>)
Allan
RickL
06-14-2006 14:53:10
 Re: Dual Chain in reply to Allan In NE, 06-14-2006 12:35:43
me neither usually had a he## time getting them off when wanted. I only do axle duals now anyway ,whole lot better in the mud. Those days are gone now thou as I don't even own set since hay and small grain is primary crop now
