Tractor Talk Discussion Forum
MF 35
NCCUB
06-15-2006 04:51:44
Buying a MF 35 with a front end loader. I don't think I will keep the loader so looking so some advise on what other models it will fit and what would be a fair selling price. I am in NC.
Thanks!
Mike M
06-15-2006 06:02:57
 Re: MF 35 in reply to NCCUB, 06-15-2006 04:51:44
Keep the loader (unless you have one on another tractor)you will find alot of uses for one once you have it.
souNdguy
06-15-2006 05:01:19
Price will depend on geographic location, style of loader, and operation. Is it fully hyd? or trip dump? does it have spools and a pump? Hoses, cyls and pump and spools ok or are there leaks?
Soundguy
NCCUb
06-15-2006 07:19:29
 Re: MF 35 in reply to souNdguy, 06-15-2006 05:01:19
I will get a better look at today. The tractor is not running and I need to see if I can raise the bucket off of the ground so I can load the tractor. Maybe someone else has run into this before. I am not sure if I will have to remove a hyd. line or what.
The bucket is all hyd. and everything in VG condition, I am in NC, I was thinking it was worth at least $1000.
Rod in Smiths Falls, ON,
06-15-2006 18:45:13
 Re: MF 35 in reply to NCCUb, 06-15-2006 07:19:29
For what it's worth, by the time I got an old pipe loader off a Ferguson TEA20 and mounted on a MF35 with new cylinders, controls and hoses, I had a bit over $2K CDN in it. That included 24 hours of labour.
Unless you have another loader, weld a chain hook onto the top of the bucket and keep it. The loader adds to steering effort but holds down heavy implements and, as a guy on this forum once told me, "It's about as handy as a shirt pocket."
souNdguy
06-15-2006 07:28:39
Maybee.. maybee not. Loaders for 8n go for 100$ and up... depending on style.
1000$ for the laoder may be a bit high.. unless it is 100% complete, functional, and minty.
Use a jack and chain and some cribbing to brace the loader up for laoding... be safe. and carefull.
good luck
Soundguy
