Tractor Talk Discussion Forum
wiring diagram for subaru alternater
jeffpapier
06-15-2006 22:00:08
I want to use an eighties subaru alternator on my Allis WD. Can anyone show me a diagram for hook-up?
jeffpapier
06-16-2006 17:39:50
 Re: wiring diagram for subaru alternater in reply to jeffpapier, 06-15-2006 22:00:08
That is the reason I want to use a Subaru alt., it is compact enough to fit inside the side rails. The AC-DELCO needs a safety shield.
Keith-OR
06-16-2006 08:52:48
Jeff, this what you are using? If so hook the terminal "R" to the B terminal on back of alternator. The one marked "L" goes to switch or charge indicator lamp, it is the excite wire for the field windings. I do not have "L" hooked up as it self excites (Same as a one wire)on my alternator.
Keith & Shawn
third party image
jeffpapier
07-14-2006 22:30:05
 Re: wiring diagram for subaru alternater in reply to Keith-OR, 06-16-2006 08:52:48
That is not quite the model Hitachi I have to use. LR155-15C? It has its' "T" shaped double connector marked S (thick wire)and L (thin wire),a battery terminal connector, and "IC REG built in" on the label.
Tim B from MA
06-16-2006 08:08:30
Jeff,
I have an original shop manual for 1993 Impreza, I'll look and see what it says about the alternator wiring and get back to you.
jdemaris
06-16-2006 05:10:34
The Subaru Hitachis hook up just the same as a Delco 10SI. I've been using them for years, they are more compact than the Delcos and they are much better built.
