Tractor Talk Discussion Forum
JD 435 oil pressure sending unit-What psi?
cdm
06-17-2006 06:22:48
JD 435 oil pressure sending unit at canister. Does anyone know what psi sending unit I should buy? NAPA has several choices.
Thank you in advance,
buickanddeere
06-18-2006 17:23:20
 Re: JD 435 oil pressure sending unit-What psi? in reply to cdm, 06-17-2006 06:22:48
40 psi max rated operating pressure.
Jerry/MT
06-17-2006 09:40:53
When I had a JD 435 it had a pressure gauge mounted at the filter and it used a pressure switch to run the hour meter on the dash. (When you had oil pressure, the circuit to the hourmeter was closed.)I never had an "idiot light" on mine.
jdemaris
06-17-2006 08:02:04
If it's for the idiot-light, it is supposed to close to ground when pressure drops below 5-7 PSI. Deere uses the same for engine oil pressure warning lights as well as transmission lube pressure warning lights. The point is, to let you know before pressure gets to zero - instead of after. I usually use NAPA Echlin OP6613 - it is set to close at 7 PSI and below.
buickanddeere
06-17-2006 06:35:42
1-800-522-7448 will get you your parts and service manuals. You should have them for this task and numerous others.
