Tractor Talk Discussion Forum
Converting to alternator
Ray Rooney
06-20-2006 05:45:07
Can anyone tell me what I need to convert to an alternator from a generator (12V). Happens to be aTD14 crawler but should be the same for any tractor. Thanks , Ray
Glen in TX
06-20-2006 10:03:32
 Re: Converting to alternator in reply to Ray Rooney, 06-20-2006 05:45:07
Here's a couple links to help:
Link
John T
06-20-2006 06:09:58
WIRING A GM 10SI 3 WIRE ALTERNATOR ON A COIL TYPE GAS ENGINE WITH NEGATIVE GROUND
This is for a GM 10 SI Negative Ground 3 wire alternator to excite it to make it work like a one wire alternator. FOR NEGATIVE GROUND ONLY
Run a 16 Gauge or so wire from the Ignition switches IGN terminal (what feeds the coil when ON) with a series 10 ohm 5 watt current limiting protection resistor to the lil No. 1 terminal on the Alternators side. (Excitation circuit) NOTE these ratings I use may be bigger than actually required, but the higher rated units have bigger leads easier to wire up. Thennnnn nnn if when you turn the ignition off she still runs from backfeed, add in a series 5 amp 50 PIV Volt Diode (IT MUST be wired + anode end to switch, - cathode end to alternator). Run a 16 Gauge wire from the Alternators lil side No. 2 terminal jumped up to the big main rear output post. (Sensing circuit) It may be a lil more accurate to sense directly off the batterys + terminal, but this is much easier. Run a 10 Gauge wire from the Alternators big output post up to the Load (NOT to battery) side of ammeter (if it has an ammeter). If theres only a 12 Gauge wire from the ammeters other Supply terminal to the battery or starter etc., I replace it with a 10 gauge.
NOTES: On a diesel where theres no coil and ignition switch I excite the alternator via an oil pressure switch. If the tractor uses an Idiot Light instead of an ammeter, it can be used to serve as the excitation voltage circuit to the alternators lil No. 1 side terminal.
John T Nordhoff in Indiana, retired electrical engineer
Joe(TX)
06-20-2006 15:19:08
 Re: Converting to alternator in reply to John T, 06-20-2006 06:09:58
It will not backfeed the coil if you hook to th accesory terminal of the switch
Joe
Mechanical Engineer
Bob
06-20-2006 08:04:07
 Picture in reply to John T, 06-20-2006 06:09:58
Link loading="auto" style="width:auto;height:auto" alt="Third Party Image">
