Tractor Talk Discussion Forum
cleaning out ditch with scrape blade
Ditch Digger
06-21-2006 08:20:01
will a scrape blade cut a ditch?
I have a 1/2 mile road in NC Mountains and I was wondering if the Scrape blade would be the tool to cut a ditch in the side of the mountain beside the road. It doesn't have to be a deep ditch just enough angle to keep the water in the ditch. The road was cut about 25 years ago with a Dozer. the mountain dirt has slowly washed and fallen down the mt and filled the ditches. We need to just drag this red clay dirt out of the ditch.
I am thinking about renting a Mahindra 5500>Link
with>Link a front end loader and scrape blade.
I am being told that the 3 point hitch will raise the blade up and down but not cock the blade at a angle to cut the ditch.
Will a 3 point hitch angle this blade or does it take a special blade.
Any advise
jlmtractor
06-21-2006 13:57:35
 Re: cleaning out ditch with scrape blade in reply to Ditch Digger, 06-21-2006 08:20:01
i would get a bobcat skidsteer with a 5 in1 bucket and just cut it out
Bus Driver
06-21-2006 13:20:19
Motor graders are long and heavy for a reason. The back blade on a tractor will tend to steer the front of the tractor in a heavy cut. I have a blade and use it. But for what you describe, I would consider hiring a motor grader. They can do some awesome work.
davpal
06-21-2006 09:56:50
I have done this many times with my 9n and rear 6 foot blade. The blades have many holes to get them at just about any angle. You want it at the most angle it will go so it is almost touching the right rear tire. Now use the 3 point arm to put the right corner of the blade very low so the left side is pretty much up in the air. Added weight to the rear blade will help it cut better as will damp ground. I usually had my dad ride on the blade for me to keep the weight on the cutting edge and let me know how it was going. Also, don't keep looking back at what you are doing or you will have a crooked ditch. Just get it where you want it and keep looking straight forward and keep the ditch line very straight. Now go back and do it again and again in the same tracks until it is as deep as you want it. You can even come back the other way and do the other side too. It really works pretty good in some cases. Good luck.
Badly Bent
06-21-2006 08:55:08
Some blades come with multiple adjustments, others only allow you to turn the blade from side to side. The design of the blade will determine whether or not you can angle it enough to make the cut you want to make.
I have a blade that allows me to swing the blade around, stopping at several adjustment points with the blade pointing forward and backward. It also allows me to tilt the blade to either side at various angles. The final adjustment on the blade allows me to slide the blade further to one side or the other for an offset cut. This would allow the tractor to remain on the road and still make a cut several feet off to the side. If the rental tractor you look at has the kind of blade, you're set. If not, you may not have the adjustability to make the necessary cuts.
The leveling box on the tractor allows you to angle the blade several inches which may be enough to do the job for you as well.
Check out the equipment before you rent it so see if it will do the job.
Tim
Rob NC
06-21-2006 08:48:38
most scrape blades or back blades are made to tilt and angle.
nballen
06-21-2006 08:47:04
Most back blades will have adjustments, where the blade can be tilted so that the left or the right corner is down, and another adjustment where the blade can be pivoted so that the left or the right end is forward and the blade moves material to the right or left.
You usually have to pull a pin out, move the blade to the position you want, then replace the pin.
The really nice blades have hydraulics to make those adjustments.
Nathaniel
ditch digger
06-21-2006 08:44:46
Great info. About what angle can you get the scrape blade to cut?
Dachshund
06-21-2006 08:27:47
Most tractors will have a "leveling box" on at least one side of the 3 point (usually the right side). This would allow for the arm to be tilted up or down on that side. Real handy for plowing. It also will help when hooking up implements that are quite set level. The blade should do fine.
