Tractor Talk Discussion Forum
MarvelSchebler Carb diagram
INCase
06-26-2006 08:24:48
I have had continued trouble with a TSX 616 (Case 800 tractor) MS carb. I had trouble with the needle seat leaking around the threads. now i'm getting alot of gas up and around the throttle plate and then running out around the shaft. This happens when i turn on the gas and try to start it it floods and i get gas everywhere. I presume the problem is a vent issue. There was a post here a 2 years ago with a diagram from a book. Does anyone have these pictures/schematics of these things? not much info in the rebuild kit. Thanks.
NorminN.B.
06-27-2006 12:22:08
 Re: MarvelSchebler Carb diagram in reply to INCase, 06-26-2006 08:24:48
third party image
Think I figured out how to add a picture. Don't know about the size though. Hope this helps you out INcase. NorminN.B.
INCase
06-27-2006 14:54:05
 Re: MarvelSchebler Carb diagram in reply to NorminN.B., 06-27-2006 12:22:08
Thanks again.
NorminN.B.
06-27-2006 15:50:05
 Re: MarvelSchebler Carb diagram in reply to INCase, 06-27-2006 14:54:05
Your very welcome, glad I could help for a change. NorminN.B.
NorminN.B.
06-26-2006 12:12:20
Hi, INcase. I have a diagram from a Oliver Tractor, M/S TSX-903, I think. It should be close to what you have, and it is more detailed than Glen's. If you want it just open your e-mail, and I will scan it for you and send it to you. Thanks, NorminN.B.
INCase
06-26-2006 13:08:12
 Re: MarvelSchebler Carb diagram in reply to NorminN.B., 06-26-2006 12:12:20
Thanks Norm.
Glen in TX
06-26-2006 08:51:59
third party image
This diagram was posted under my handle in parts & pieces photo gallery. You need to shut the fuel off at the sediment bowl when not using it. Also try a needle seat kit in another brand maybe? I've had trouble sometimes with ones from Zenith/Marvel Schebler kits not fitting right but not often. Usually threads are messed up from someone tightening it too tight or crossing threads from installing a poor fitting generic one. Sounds like the threads on seat or needle is still leaking. Thread repairs in casting and refacing the seat thread surface may be needed. Also shake the float to make sure it isn't laden with fuel inside. You can also hold the float with a pair of pliers in a pan of hot water (not boiling) and see bubbles spewing from it if it has a leak. After draining fuel you can solder leaks shut on them but new floats are available reasonably. The TSX floats are also bad about collapsing some and if it's like that replace it with a new one to get back the buoyancy needed to keep the needle shut.
NorminN.B.
06-26-2006 16:38:23
 Re: MarvelSchebler Carb diagram in reply to Glen in TX, 06-26-2006 08:51:59
e-mail sent..... ..NorminN.B.
