Tractor Talk Discussion Forum
Jerky loader
RegoR
06-27-2006 06:52:43
No, I'm not name calling! ;-)
The more weight there is in the bucket, the harder it is to raise the bucket smoothly. In fact, sometimes it's just about impossible to avoid a sudden jerk at the start of the lifting. It's a Wagner loader. I thought there might be an adjustment at the valve handle return spring, but there isn't. Is there a solution short of replacing the control valve unit?
Thanks,
Roger
RegoR
06-28-2006 06:36:45
 Re: Jerky loader THANKS! in reply to RegoR, 06-27-2006 06:52:43
Thank you all for the suggestions and comments.
Roger
Hermit
06-27-2006 18:14:29
 Re: Jerky loader in reply to RegoR, 06-27-2006 06:52:43
You might want to make sure you're using a non-foaming type of fluid in your hydraulic system.
arlobenn
06-27-2006 17:03:23
Ther is a nonserviced check valve built into the control valve. Had to replace mine 2 or 3 times.
RustyFarmall
06-27-2006 07:28:44
Like the others said, air in the system or low on hydraulic fluid. Make sure that you sufficient oil in the reservoir, and then run the loader up and down several times without lifting anything. If there is air in the system, this should allow it to work its way out.
old
06-27-2006 07:16:34
You may have air getting in to the system by way of a hole in the sucktion line going to the pump. Or it could be a relief valve going bad/weak spring. Or the pump maybe going bad on you, any and all of those could be your problem
Ryan - WI
06-27-2006 07:04:00
Sounds to me like air in the system. The air will compress until there is enough pressure than jolt like a nail gun.
