Tractor Talk Discussion Forum
10 20 mccormick
airpumper_1
06-27-2006 11:16:53
during what years did they build the mccormick 10 20? how do i identify what year mine was built?
Nebraska Cowman
06-27-2006 17:31:03
 Re: 10 20 mccormick in reply to airpumper_1, 06-27-2006 11:16:53
All you have to do is crawl under the tractor and look. The casting date is cast in the main frame back under the transmission area.
K-Mo
06-27-2006 12:10:03
10-20s ran from 1923-1939. If it has the original engine the enigine number would probably be the same.
From MD Manual: "Serial shop number is stamped on name plate on rear wheel shield or in center of hood sheet, rear." The serial number will have "KC" or "NT" and the sequence number. I don't have access to mine at the moment, but I believe my serial number is on what I call the engine firewall.
I don't see the 10-20 serial numbers listed on the left, but if you find the number some one should be able to help.
K-Mo
sjh
06-27-2006 11:27:53
If you have your serial # look to the left and look under research and info. There is a serial # lookup. It will also tell you production years.
