Tractor Talk Discussion Forum
Farmall H M rear wheel weight bolts
Don L C
06-27-2006 14:14:52
Just for information the bolts are 4 1/2"long--- 4"are too short --- 5"are too long..... I believe 1/2" dia.....
doogdoog
06-28-2006 02:34:23
 Re: Farmall H M rear wheel weight bolts in reply to Don L C, 06-27-2006 14:14:52
Aloha, Like Nebraska Kirk said, tap & die set. Get the 5" bolt and run the die down to what is required and then cut the bolt.
Mahalo,
doogdoog
massey333
06-28-2006 04:48:38
 Re: Farmall H M rear wheel weight bolts in reply to doogdoog, 06-28-2006 02:34:23
Is there something wrong with 4-1/2" bolts that we don't know about??Any Equipment dealer will have them.
RustyFarmall
06-27-2006 14:52:26
Yep, 4 inches is too short, and the threads don't go down far enough on the 5 inchers.
Nebraska Kirk
06-27-2006 19:54:44
 Re: Farmall H M rear wheel weight bolts in reply to RustyFarmall, 06-27-2006 14:52:26
That is why they make tap and die sets :-)
RustyFarmall
06-28-2006 04:49:20
 Re: Farmall H M rear wheel weight bolts in reply to Nebraska Kirk, 06-27-2006 19:54:44
You would also need a lathe so you could turn down the shank a bit. The threaded portion of those bolts is slightly smaller O.D. You can use a die and run the threads down a bit further, but the threads do not cut cleanly and you run the chance of breaking the die. Not to mention that it takes a whole lot of muscle. Just about any farm machinery dealer will have the 4 1/2" bolts in stock. A common hardware or farm supply type store will not have them.
RAB
06-27-2006 15:08:44
Washer them up?
Regards, RAB
RustyFarmall
06-27-2006 17:47:38
 Re: Farmall H M rear wheel weight bolts in reply to RAB, 06-27-2006 15:08:44
It would take several washers, and you would still have a lot of the bolt sticking out.
